We'll I finally got my friends scanner to work, and of course tested it out. Here's the pics from installing the tranny cooler and the CAI.
Enjoy.
And check out the pics from the swaybar install in the suspension section.
-mobiuslogic
Pipe cut and routed and the filter taking a pose. Silicone turbo hose connectors and 5/8" stainless steel smooth band lined hose clamps (no cutting the connector and a bit better than only a 1/2" band)
http://www.supermotors.org/getfile.php?id=126921&toggle=fullsize&f=.jpg' alt='' width='600' height='390' class='attach' />[/url]
Here's how it all looks.
[url=http://www.supermotors.org/getfile.php?id=126922&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=126922&toggle=fullsize&f=.jpg' alt='' width='600' height='390' class='attach' />[/url]
The filter in the wheel well and mounted as high as I could get it to prevent hydrolocking in the FREAK occurance that it actually rains here in CA. :D
[url=http://www.supermotors.org/getfile.php?id=126925&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=126925&toggle=fullsize&f=.jpg' alt='' width='600' height='386' class='attach' />[/url]
Here's a diagram of how I installed the tranny cooler. The tube that returns the fluid is above the cyan line. Normally this tube is connect to a rubber hose that then connects to the inlet on the tranny. I pulled off the rubber hose and spliced in right there. Works perfect and no leaks.
[url=http://www.supermotors.org/getfile.php?id=126923&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=126923&toggle=fullsize&f=.jpg' alt='' width='391' height='600' class='attach' />[/url]
Here's how it looks attacted to the air dam. Those are the hoses of course. Works pretty good too in this place. Good call SHOZ123 :thumb:
[url=http://www.supermotors.org/getfile.php?id=126924&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=126924&toggle=fullsize&f=.jpg' alt='' width='600' height='390' class='attach' />[/url]
Another shot from the front. And I know all you mid-westers are jealous, what with your rain and snow. Madness. :ph34r: :D j/k
[url=http://www.supermotors.org/getfile.php?id=126926&toggle=fullsize&f=.jpg][img]http://www.supermotors.org/getfile.php?id=126926&toggle=fullsize&f=.jpg' alt='' width='591' height='381' class='attach' />[/url]
Enjoy.
-mobiuslogic
