I am painting my calipers and using paint that I can bake to cure harder.
Can anyone tell me how much heat the rubber boot around the break piston can handle?
What temp can the two rubber boots on the caliper bracket handle?
Thanks
Adam
You only need to bake at like 250 degrees. Boot should be OK, but you can remove it if you want to. The heat from daily driving bakes it pretty good, also.
