Welcome to the TCCA!
The first problem could be suspension related. My first guess would be warped rotors. You could have warped the new ones if your calliper is not floating correctly(pins are jammed up). Usually a suspension or tire problem will exibit itself during all driving situations, so i doubt it will be that.
Your secons problem seems like a loose connection. There are no bulbs in the radio, its an electroluminecent sheet, so its probbaly a bad dimmer swich or bad connection behind the radio.
Sorry i could not help more.
Brad
Brad
