I have a 2003 which suffered a curb strike. It broke the rim (aluminum) and bent the control arm. I noticed a grinding sound after the hit. I replaced the lower control arm, rim, tire, ball joints, both front struts, and brake pads but the impact side is still having a grinding sound. It looks like the pad is rubbing on the rotor. When I let it coast in drive on stands and that wheel off the good side spins freely, while the other side either stops completely, or spins slowly then periodically halts. I'm worried it's the bearing or the differential. I'm not seeing play in the tire when I rock it at 12-6, 3-9.
I've run out of ideas on what I can adjust/replace. Seems like the caliper is misaligned.
