14"width, 16"depth, 12"height... 1.00cf+/-
sub is a pioneer TS-W2501D4
2500w max :dunno:
800w rms :D
18-1000hz :thumb:
calls for .90-1.2cf for ported box :blink:
is this box good? or should i biuld it like a standard slot vent box? :dunno:
With a port that long, it looks like it's going to be tuned high. And you missed a 45* corner. Good design though.
i see the corner... :blink: is there any way to biuld a box that will "HOUND", with out all this tuning stuff? :dunno: and if not how could i tune this setup lower without taking up my entire trunk?
<div class='quotemain'>
i see the corner... :blink: is there any way to biuld a box that will "HOUND", with out all this tuning stuff? :dunno: and if not how could i tune this setup lower without taking up my entire trunk? [/b][/quote]
You just need to vary the length/width of the port to tune it just right.
http://www.2k4civic.com/portcalculator.html
The box volume is calculated after you compensate for port volume. Given your 14x8.5x12 (internal dimensions) airspace for the woofer, you only have ~.82cuft. You need to get it to 1.0cuft, and THEN add the port volume.
A 1.25x12x30" port will be tuned right around 35hz. Like Mike said, somewhat high.
