1 - 2 of 2 Posts
Can anyone tell me the easiest way to bleed the 4 wheel disc ABS system on a 95 Taurus. I had a caliper off for about 20 minutes and lost a lot of fluid. I know you have to run the ABS motor and open some valve or something and then do the bleeding. Can anyone help me. Thanks.
well usually you would use a scan tool and run the ABS brake bleed procedure but since you probably don't have one, you can go out on a Dirt or gravel road or a wet parking lot and just nail the brakes. It worked for me on my 96.
jarod
1 - 2 of 2 Posts
