I just flushed transmission per the sticky. I found black plastic pieces (about 1/8" dia) in the drain bucket, about a dozen. But I found none in the oil pan. Can something like them come out of trans? I am not 100% sure if they really came out of trans or fell off from the car.
The trans filter has some black plastic on it.....was yours tore up when you replaced it?
The filter was undamaged. As I said, the trans oil pan had no such debris. Yes, I replaced the filter, too.
I googled for "plastic piece transmission oil" and found plastic thrust washers can break up. What do those do?
Are you sure those are not round metal pices - used sometimes as spacers from the old rubber gasket?
No they are not metal. I know no black metal. They are hard but not metal hard.
