This happened last night, while making my weekly 5 hour commute. About 2 1/2 hours into the drive, there is a hilly region where the cruise ordinarily will downshift and RPM's go up to about 3500 for a while. "A while" being 30 seconds to 2 minutes. Duration of downshift depends on load and setpoint, and I used to be very nervous about this, but eventually I figured "I'm burning out carbon deposits", and it's nowhere near the redline.
Anyway, I hit the first uphill segment, and when I reached the top of the hill I touched the coast button (as I normally do) to get it to shift back to normal RPM's. Everything normal. Then I hit the next uphill segment, and when it downshifted, RPM's went to 3500 as always, BUT, the headlights went very dim and the battery indicator light (for the charging system) was flashing rapidly on and off. As I began to realize that my alternator was dying in the middle of the night, in the middle of nowhere, I hit the coast/decel button to drop the RPM's down. When the RPM's dropped down, the trouble vanished, and did not recur during the rest of the trip. 2-1/2 hours later, as I pulled into my destination, I briefly revved the engine to 3500 RPM to see if it would cause the headlights to dim and the battery light to come on. It did not. So RPM's alone are not the cause. Car ran fine today. Later in the day, in an attempt to re-create the problem, I accelerated uphill with 3500 RPM and headlights on, everything the same as last night, but did not get the light show.
If it were the alternator, I'd think it would stay bad. I replaced the brushes last spring, so I don't think it's brushes. Also checked bearings for play at that time; there was none. I have a hard time imagining the diodes / regulator in there could go bad just for a 30 seconds and then go good again.
Could the tilt from going uphill cause the electrolyte sloshing in the battery to create a momentary short? But then how would the timing coincide exactly with the RPM's dropping back down to normal? Seems possible, but not plausible.
Could the solenoid that kicks in for downshifting be momentarily shorting out the electrical system? It seems to fit the symptoms perfectly, but seems unlikely from an electrical standpoint. Solenoids typically fail by failing to actuate; a mechanical phenomenon. Electrically, I have only ever seen them go open, not short. Once open, they tend to stay that way. I cannot imagine how a solenoid could momentarily short, unless there is a bad connector.
Could there be a problem with the heavy ground or power connections between battery, alternator, and frame that would act this way? This seems most believable as a failure mode but doesn't seem to fit behavior too well.
Car has 230,000 miles and gets regular oil changes every 3-4,000 miles.
Possibly unrelated, it has had a few rough cold starts in the last 4 months. At one time set a P0301. Examined cylinder 1 plug and found nothing. Sprayed plug wires with WD-40 and juggled wires 1 and 5 at coil pack to see if code follows coil or wire, but code has not set again since then. I'm wondering if somehow a coil pack that is on the edge of failing could produce this bizzare and scary behavior.
I'm hoping to reproduce the problem sometime in the next week so I don't have to experience another knuckle-biting 5 hour drive. Making it reproducible makes it easier to confirm a good fix.
Any ideas?
Any ideas?
