1 - 13 of 13 Posts
Looking to purchase a new better quality C Clamp to do my front brake job pushing the caliber piston back when installing new pads....
I am wondering what the best length is for a C clamp so i don't waste my money going too big.
Also what is the best size on the end of the C clamp to be, about the size of a quarter? Larger, smaller?
Thanks
i just normally use a 4" standard C clamp... it works nicely for the job... it has about a nickel sized end on it, i think it would be better if it were considerably bigger, im sure somewhere someone makes a c clamp especially for the job, maybe even with the end shaped to the contour of the piston. to answer your question, a 4" will be perfect.
Discussion Starter · #8 ·
no sales on the craftsman c clamps when i was there for the BF sale, so i guess i will go with the harbor freight C clamp , since it will get used very rarely it should last.
This is the one I use. Especially on rear caliper pistons that need to be "screwed" back into the bore, they don't push straight in.
Caliper Tool Set for Disc Brakes
When I used to use a C-clamp (Craftsman 8"), I always put one of the old pads in front of the piston face to protect it and distribute the force of the C-clamp evenly on the piston while pushing it in.
Unless you have a link for a reasonable priced caliper spreader i am more inclined to purchase a $10-15 C- Clamp that will get the job done. The ones i keep seeing on Google searchs are rather expensive.
As posted below they are fairly inexpensive. I just went to my local parts store to get it. Didn't bother with a search.
Goto AutoZone or Advance and buy this: Disc Brake Pad Spreader
$9 at my local store.
Similar to the one I got.
1 - 13 of 13 Posts
