Clean all the pulley contacts where they meet the belt. Replace the belt. Do NOT use belt dressing!!!! It does not help the situation, and can actually cause the belt to prematurely soften or glaze. If the pulleys are clean and the belt is new, the problem WILL go away!!! Belts are cheap and easy to put on. Don't buy the cheapest one though......Originally posted by sabledale@May 15 2004, 04:17 PM
replace the belt and then use belt dressing if needed.
Clean all the pulley contacts where they meet the belt. Replace the belt. Do NOT use belt dressing!!!! It does not help the situation, and can actually cause the belt to prematurely soften or glaze. If the pulleys are clean and the belt is new, the problem WILL go away!!! Belts are cheap and easy to put on. Don't buy the cheapest one though...... [/b][/quote]Originally posted by 00Taurus+May 15 2004, 07:45 PM--><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (00Taurus @ May 15 2004, 07:45 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-sabledale@May 15 2004, 04:17 PM
Bingo!Originally posted by silvapain@May 16 2004, 01:02 AM
I use belt dressing as a belt tester - spray a little on, if the squealing stops, the belt needs to be replaced. Belt dressing is not a fix, but it is a good tester.
Huh?Hi: You can try some PAM cooking spray
