"The lower ball joint is an integral part of the steering knuckle. If the lower ball joint is found to be defective, the entire steering knuckle must be replaced. "
Is this true?? I found a ball joint seperately in autozone... then how can the above be true??
Also what arre the symptoms of a failing ball joint...?
