My 97 Taurus (33K miles, AT, Duratec engine) is at the Ford place right now. I am trying to figure out which direction to go to make sure it is fixed correctly.
A little history...a few weeks ago, the transmission slipped for the first time. There was no leaking but I had to drive in second gear all the way to the local Ford place. They said that the trans. fluid needed changing and they cleaned the filter as well. They commented that no metal shavings were evident so that was a good sign. They also said that I had a crack in my gas cap which also caused the "Check Engine" light to come on (which I guess was a coincidence since it all happened the same day). I even had the cooling system flushed and changed. $320 later, I thought everything was OK, and only drove my car around town for the last month, thinking all is well.
Last Friday, I was heading to Dallas and after driving about a 100 miles, I felt O/D gear slip. I disabled O/D but I noticed that I was losing power in 3rd gear too. I was forced to drive in second gear (manually shifted it to second). Fortunately, I was only 10-12 miles from a Ford place in Waco.
At first, I was told that I lost almost three quarts of fluid and may need a new transmission (approx. $2500). Later, I learned that there was no metal shavings in the pan so it is probably my torque converter (approx. $1000). Today, I received a call and was told that I might just need a new gasket and new fluid but they would pull the convertor out to check it for damage. If it's good, then the cost will only be $750.
Here's my question...should I have the torque converter replaced even if the Ford place thinks its still good? Something is causing the problem of slipping. Just replacing the fluid for the second time in a month (and a gasket for the first time) is not leaving me feeling very confident. I hate to spend $750 now (without the torque converter) and then find out a few weeks later that it should have been replaced and then spend another $1000. Any thoughts from those who may have had a similar situation?
--TexasTaurus (Eddie)
