Welcome to tcca.
Wow, sounds like you have had a lot of work done. I've read quite a bit in the past that the vehicle speed sensor seems to go out after the transmission has been replaced which causes bad shifting. I dont know if that is your case, someone else could probably shine in.
About the rest of the problems, are you sure everything was connected back properly after the headgasket repair? All sensors, wiring harnesses, etc?
If all else fails, I'm holding my support group at 10pm sharp
