I have a 92 SHO, and I know I have a bad motor mount. First off, the DIS module does not sit right because the engine is too far down. The reason I believe its a mount is because when I jacked up the car to get a better position on the motor to get at the Cam sensor, the motor moved into place, everything looked right. The Module would sit right against the motor like it should. The other reason I know its a mount is because the engine moves around a lot more than it should once its running. I'm not quite sure if its the front left mount or the rear mount...I was wondering if anyone else has had this problem...thank you.
