Bad Evr?
1145 Views 0 Replies 1 Participant Last post by  GreyHawk
91 3.0L - How do you check the EVR? I used a hand vacum pump to test the line to the EGR and it didn't hold any vacum. I then went to the engine vacum side and got the same results. Turned on the ignition and had the same results. I pulled the EVR and checked the resistance and got 0 ohms resistance. Is this correct and how much is a EVR?
1 - 1 of 1 Posts
1 - 1 of 1 Posts
