1 - 2 of 2 Posts
When changing atf and filter, which cooling tube (pipe) does the built-in black plastic filter clip go over (straddle), or does it matter? Tia.
I forget which lube tube it clips to..... I just put it in so the longer side is parallel to the pan flange. No idea if this is the "correct" way, but it always worked for me.
1 - 2 of 2 Posts
