Symptoms,
1,2nd gear shift with a violent thud, 3rd and OD intermittently drop in and out of gear for no reason what so ever, and an occasional speedo bounce. the column shifter is all sorts of messed up. i have to count to put the car into gear because the trs is very very off. n=park d= n
so anyways i replaced the VSS, a nightmare in itself, the sensor broke off in the transmission so i had to drop the exhaust which had metric and Standard bolts one with a lock nut on it, very ghetto. impacted the lip of the broken VSS out of the trans and installed a new one, put the exhaust back on and reset the computer, drove fine for a good 20 or 30 miles then the same problem started again Very hesitant to shift out of first, and when it finaly does around 4 or 5k rpm with a loud thud, second to third to od jump out of gear randomly
im pretty sure its nothing short of a full transmission job, but im going to swap the TRS out for one i pull at a junk yard.
any suggestions? or could it be a bad solenoid?
the tranny fluid is new and the pump appears to be working, so i guess the TRS, since the column shifter is all messed up.
some one said on here the a bad cps and syncro shaft could also cause similar symptoms.
i figured id let you guys chim in and enlighten me.
