If you are talking about the separator plate/gasket I would not unless it is damaged.
If I replace the retaining clip, do I need to replace the seals on the pump shaft. Im ready to do this, but the little stuff is starting to arise that I may not know the specifics about. Im very mechanical and have been inside engines, but never inside a trans. The write-up on the repair is very good, im just wondering about the little stuff that may have been omitted.
Thanks
well if your not use to working on it will give you best advice.. take it to a trany shop.. for about 200 let them do it ....it can become a nightmare fast
My lock-up solenoid is reading 18+ ohms which is way out of spec according to the info I have, could that cause me to lose OD?
thanks
98 AX4N 3.0 Vulcan
For the '98s and up the TCC resistance should be between 13-24 ohms.
SHIFT CONCERNS: NO 3-4 SHIFT (AUTOMATIC) Possible Component Reference/Action
222 — ELECTRICAL ROUTINE
Powertrain Control System
· Electrical Inputs/Outputs, Vehicle Wiring Harnesses, Powertrain Control Module (PCM), Shift Solenoid SSC, TR Sensor, Internal Wire Harness, VSS
· Run On-Board Diagnostic. Refer to Powertrain Control/Emissions Diagnosis Manual 1 for diagnosis. Perform Pinpoint Tests A and D using the Rotunda Transmission Tester. Service as required. Clear codes. Road Test and rerun On-Board Diagnostic.
322 — HYDRAULIC/MECHANICAL ROUTINE
Overdrive Servo Assembly
· Perform Air Pressure Tests as described.
· Apply Rod incorrect
· Inspect. Replace if incorrect.
· Servo Bore or Piston damaged, incorrect
· Inspect for damage. Service as required.
· Piston Seals—damaged
· Return Spring Retaining Clip—broken, missing
Main Control Valve Body
· Bolts out of torque specification
· Tighten bolts to specification.
· Gaskets and Separator Plate—damaged, off location
· Inspect for damage. Replace as required.
· 3-4 Shift Valve, Line Modulator Valve, Forward Clutch Control Valve—stuck, damaged
· Inspect. Service as required.
· SSC not functioning properly
· Activate solenoid using Rotunda Transmission Tester. If solenoid operation cannot be felt when placing hand on solenoid, replace solenoid. Inspect O-rings for damage. Service as required.
3-4 Accumulator Assembly
· Accumulator Piston—damaged
· Piston Seals—missing, damaged
· Springs—damaged
· Rod or Bore—damaged
OD Band
· OD Band—damaged, worn, misassembled
· Direct One-Way Clutch Assembly damaged
1 Can be purchased as a separate item.
Thanks for the reply, I guess Ive got no other choice but to pull the valve body. I was grabbing at straws trying not to pull it. I have not bought any gaskets or shaft seals yet, I was hoping that I wouldnt need to.
