Concerned that my tranny's about to blow up, I'm going to grab an AX4N from the boneyard to rebuild. I know I need the PCM, I know I need the axle shafts, and I know I need a bunch of other stuff, maybe. I'm also going to grab the floor shifter out of an SHO, because the column is angering me.
So, I know these things were mated to the SHO V8 that made 235 hp at 6 grand, and 230 ft-lbs eventually, at some point in time. While my vulcan has given my 4S a good thrashing, it's not exactly capable of tearing out the insides of a 4N... yet. When the subframe's down for the tranny swap, I'm planning on redoing the valvetrain and throwing in a more aggressive cam.
Looking ahead to the hell I'll subject this new tranny to, I'm trying to make it the best I can. There's only one shift kit I can find (unlike the two for the 4S). Is that all I need to add to the valve body? I'm also getting one of SHOsource's torque converters once Matt & I can sort out shipping to this frosty wasteland I call Canada. One other thing I'm looking at is 3.98 gears, though I don't know the cheapest option of going about that. I'm ordering the Master kit off bulkpart.com, too (and the manual). Also, it's getting a beefy ATF cooler. Is there anything else internal I should look into for strength/durability? Anything I'm forgetting about?
Also, how different are PCMs? Chassis-wise, are all programs loaded, and it just operates based on what signals it gets; or if the donor car had a 6-disk CD changer and mine didn't, it'll back-fire the engine or something? Would I be safer taking the box to a stealership and explain the situation?
And one other thing... are the chassis wiring harnesses the same? Will I easily be able to find wiring to route the O/D off button, or will it be studying all 14 different PCM pin configurations and running new wires to it?
Fun fun.
-Dan
Fun fun.
-Dan
