New member, 1st post.
1st let me say THANK YOU ALL SO VERY MUCH FOR ALL THE FREE INFORMATION I HAVE FOUND HERE ON THIS FORUM !! IT IS ABSOLUTELY ASTOUNDING !!
Ok so I broke out the #18 line wrench. Gave it a go and almost rounded the nut. Sprayed her down with penetration oil let her sit over night. Tried again today.. nada. I am afraid I will round the nut if I try to hard, or brake something like the line, or possibly the fitting off in the housing ( which as we all know WOULD SUCK HORRIBLY)
Should I apply heat? More penetration oil? Or am I missing a step?
Mine are not quick disconnect unfortunately. They have those gay tin secondary retainer clips, and NTP fittings.
( OHHHH... this is on a 1994 Taurus GL 3.0L Vulcan non-flex.)
1st time messing with an auto trans so help me out if you can.
Manual I can do easily but auto's have been my kryptonite.
I down loaded the VERY NICE PDF file AX4-S service manual by ATSG I found on this forum ( A BIG BIG THANK YOU THERE BTW !! )
What I am trying to do is replace the front pump seal ( at least I think its the pump seal, could be the converter seal ? ) as well as the solenoids. MAYBE a valve body rebuild and replacement clutches if I feel confident enough. If not I will drop off the valve body and the clutch assemblies and have them reworked at a shop.
The way things started:
No slipping, but it DID start holding gear once it shifted into a higher gear on me though. Then dumping into a lower gear only when I almost came to a complete stop. So I replaced the TPS, and the neutral safety, cleared the codes and it went away. YEAH ! *NOT* 2 days later it came back. Cleared the codes again and it went away again. @ days later it came back again. Buddy who owns a trans shop says the code indicates incorrect gear ration which usually means a sticking solenoid.
So after it was cleared and came back the second time it sprung a BAD leak coming from the under side of the trans bell where it buts to the engine. ( hence I am unsure if it is the converter, converter seal, OR the front pump seal yet. )
But so far.... the only thing holding me up are these frick'n lines ! *ARG!!*
Whats the trick to getting them off ?
I think I will also document bolt sizes.
All the articles I have read always leaves those out.
I think if I document them for future users it would save them a lot of searching through the old tool chest.
Thanks !
Duane
Thanks !
Duane
