When on automatic setting or when fob unlocks, all lights on. When switch moved to manual, only headlights - no dash or tail lights. Put in new headlight switch but didn't fix. Would appreciate any ideas. All fuses appear OK. Been reading about relays and GEM. Could it be one of those? Appreciate any help.
There are some important AutoLamp wires that ground out in the steering wheel column. Have you tried adjusting the tilt of the wheel and retesting the headlight switch operation?
Got it fixed after three years of putting it off. Problem was a bad connection on a soldered relay behind fuse 29. Fuse was fine but showed high resistance. Crimped it from back and is working fine now.
