21 - 27 of 27 Posts
· Registered
Discussion Starter · #21 ·
If you're creating positive pressure in the intake tract, that would be "ramming" the air in. By "positive pressure", i'm talking about a system that has pressure within the intake tract WITH THE THROTTLE CLOSED i.e. there is no suction drawing air into the intake tract. The intake tract is literally being "force fed" or "rammed" air regardless of the vacuum of the motor. Granted, it might not be the same thing as running a turbo / super charger under boost, but it is "ram air" none the less. As previously mentioned, a Magnehelic gauge can be used to measure changes ( good OR bad ) in air pressure within the intake tract.
The key here is to not only produce positive pressure under the above conditions i.e. with the throttle closed, but also be able to maintain that pressure under Wide Open Throttle ( W.O.T. ) conditions. This dictates that you have a FAR greater volume of air being forced into the intake tract than anything that the motor can ingest on its' own. When you can pressurize the intake with a HIGH volume of cooler air during normal operating conditions, you ARE going to show performance gains in both 0-60 and 1/4 mile times. That is, so long as your fuel system can keep up with the higher levels of air flow.
Anybody with their air inlet mounted under their hood, or especially in the fender well, can stand to gain LOTS from doing some research on the subject. Sean
· Registered
Put a large scoop (i.e. dragster) on the hood, connect it directly to the intake and you still won't measure positive pressure (greater than a few inches of h2o) at 100+. Forget anything less.
As for measuring boost at closed throttle, how does that mean anything for performance? With a closed end pipe, any air moving in the same plane will produce a very slight positive pressure. Look up Pitot Tube and you'll notice units of measure as inches of water, which are fractions of one PSI.
I'm with loudsho92. If there was an effective, true ram-air system, it would be on every car made to help CAFE.
· Registered
Discussion Starter · #23 · (Edited)
I would suggest doing some snooping around Autospeed.com and looking at some of the testing that they've done. In several different cases, simply REDUCING "negative pressure" within the air intake tract has been worth .2 in 0-60 times. This would translate to even further gains in 1/4 mile times. This was not even achieving POSITIVE pressure, simply minimizing negative pressure.
Outside of that, your comments about "ram air" improving CAFE is absolutely 110% backwards. Cold air is denser than warm air and requires more fuel. More fuel means higher emissions AND lower mpg's. Most manufacturers are specifically working with warm air intakes for this reason. I've seen multiple Mopar's that draw air in from directly behind the radiator for this very reason. Then again, they were working with Smokey Yunick, the "inventor" of the hot air engine. I do something like this every winter with my daily driver. The difference in MPG's is VERY measurable.
If you want to go the opposite route i.e. making more power at the expense of economy and emissions, the highest pressure point on a vehicle is directly in the front middle of the bumper i.e. right where the license plate mounts in some States. If your bumper is plastic and is of a hollow core design, this can make for one helluva transfer tube to other large diameter ductwork that feeds up to your airbox. Obviously, you have to do some surgery to seal it up and achieve high flow routing. Adding a small radiused flare at the inlet further increases the ability to capture air.
Like i said, do some research FOR YOURSELF and see what YOU find. A magnehelic gauge won't set you back more than $30 including shipping on Ebay. Believe me, i've got a couple with different ranges. You don't have to be under "boost" conditions to improve volumetric efficiency. The greater the cylinder fill, the more potential for power and atomization of the fuel.
Outside of the increased net cylinder pressure due to greater cylinder fill, for every 10*F reduction in intake temperature, a 1% increase in power will be realized. If drawing in hot air from under the hood behind the radiator in a low pressure zone, moving your intake to an outside high pressure zone will help you to realize some of the potential that you have for power gains in this area. Sean
· Registered
If you are attempting to argue a theory, why do these paragraphs contradict each other? If you want a warm air setup, go back to the round filter sitting on top of the engine. Find a major manufacturer using that design. I dare you.
· Registered
Discussion Starter · #25 ·
They do not contradict each other, they reinforce each other.
If you have higher volumes of colder, denser air being fed into the motor, you are going to consume more fuel and make more power. This comes at the expense of higher emissions and poorer fuel economy.
If you have lower volumes of warmer, thinner air being fed into the motor, you are going to consume less fuel and make less power. This comes with the benefit of lower emissions and improved fuel economy.
On my daily driver, i run a cold air set-up in the summer to try to offset the higher ambient air temps and reduce the potential for detonation. Due to higher levels of traction on clean, warm pavement, the added power can help the car to run a bit quicker.
In the winter, i run a warm air set-up as i have limited traction and don't need as much power. I also want the car to warm-up faster and run more consistently regardless of how cold it gets outside.
I am not worried about emissions or meeting CAFE standards. On the other hand, automotive manufacturers have to be concerned with both of these, and as such, strive to seek a balance in their product line. As such, they use cold air systems for a few select high performance models and try to balance that out with the rest of their product line, which typically run warm air systems.
Pretty simple really.... Sean
· Premium Member
In my opinion, if you are having to swap your intake style every six months, your intake air temperature sensor isn't working right.
Since the PCM monitors incoming air temperature and oxygen content of the exhaust, there shouldn't be a problem besides what optimally works best. It isn't a question of air density, but of oxygen content.
Also, by your definition my '95 Taurus is high-performance because I can guarantee you that it is cold-air intake because it pulls the air from the driver-side fender and not the engine bay.
Just an observation here, but why are you being controversial with less than 20 posts to your credit? Is it your hobby to go around trolling/irritating different car sites for fun? Unless you have a degree in Mechanical or Chemical Engineering, you are probably using vocabulary above your education based on your previous posts.
· Registered
Discussion Starter · #27 · (Edited)
What does the number of posts that one has on a site have to do with their level of knowledge, experience or ability to be right, wrong, helpful or "controversial"?
I have built everything from a 482" Weber carbureted Olds motor to a turbo-charged small block Chevy to a dual quad cross-rammed Ford 302" motor. There are WAY more in-between those that i won't bother mentioning. I currently have a 2.5L motor that i'm building from scratch and will soon be tearing into my Harley motor.
Twenty+ years ago I worked as the head of mechanical maintenance for a large corporation. I was responsible for 30+ vehicles ( cars, vans, box trucks ) and HORDES of mechanical equipment. This meant everything from automotive engine swaps to rebuilding high pressure pumps, repairing high voltage ozone generators, etc...
I currently work in the electronics field and have run my own business for the last 15 years. Outside of my regular work, I have done design consultation work for over a dozen world class manufacturers. I have also had articles published in magazines and been quoted by manufacturers in their sales distribution literature. I'm NOT trying to "toot my own horn", i'm trying to give you background and help you to understand that i'm not using words / lingo / verbage / ideas that i don't comprehend.
As to my seasonal warm air vs cold air induction system swap, cold motors are less efficient and produce less heat in the winter. Using warm air brings the motor up to operating temp quicker. This not only increases engine efficiency and lowers fuel consumption and oil dilution, it also helps to make my personal commutes more comfortable. I understand that the computer attempts to maintain the same air / fuel ratio, but it can only do so much on its' own. I'm simply helping it along with a simple mod that takes me less than ten minutes to perform once in the Fall and then again in the Spring.
Outside of all of that, fender mounted air intakes typically don't work all that well. The inside of a fender is typically a low pressure zone, and many times, can be at negative pressure. Due to the lack of positive pressure and turbulence in that area, the motor gets no assistance when it comes to drawing air into the intake system. Since the natural vacuum of the motor now has to work harder to draw air into the cylinders with no outside assistance, the air tends to be slower moving. Slower moving air typically results in lower ratios of cylinder fill with the resultant drops in volumetric efficiency. On top of that, the air found in this area is typically warmer than the ambient temp. This is due to heat from the cooling system, engine compartment and tire collecting there.
To sum things up, fender mounted air inlets typically aren't all that great on MOST cars. The lack of turbulence and predictable air flow levels within that area does help make it easier for the "engineers" to program the ECU though. By limiting the variables that it will encounter, the ECU can now operate more consistently. This is one of the reasons why heavy modifications to the motors intake and / or exhaust system may require reprogramming or "chipping" for optimal results. Factory ECU's simply aren't programmed to deal with a wide set of variables. Modifying one's vehicle way beyond the programmed set of variables that the ECU can deal with can easily result in poorer rather than better performance.
This why i suggested picking up your own set of magnehelic gauges and doing your own homework. Fender mounted air inlets are typically NOT "high performance". It is NOT hard to beat the diploma holding "engineers" at their own game, especially when it comes to individualized optimization of your own vehicle with free labor vs mass produced products using costly labor. Most mass produced designs are dumbed-down for profitability and ease of production. Our cars are no different.
I'm NOT trying to be "controversial" by any means. I'm simply stating facts that are easily verified by those that are willing to do some simple research. If I ever post something that you don't understand or use terminology that you're not familiar with, simply ask me for clarification. I'll be glad to not only explain it as best i can, but also provide specific points of reference.
In the meantime, i'm still looking for help / info pertaining to my original post. I don't know it all, hence my research in this area and my asking for help on this forum. Sean
21 - 27 of 27 Posts
