What would you guys recommend to push 800 Watts at 3 ohms, preferably with something like a remote so that I can turn down just the subs independently. Thanks.
-mobiuslogic
-mobiuslogic
And hook that to a compatible head unit that can control it (i think you can get them) or this RUX-4280 Remote Control Centre1800W MAX Power
• 1000W x 1 (2ohm 14.4V)
• V12 AccuClass-D™ Design
• New Gain Factor (patent pending)
• Digital Control Center with LED Display
• Bass Engine® DSP:
- Parametric EQ
- Crossover
- Time Correction
- Subsonic Filter
- Phase Control
- Bass Compensator
• Buffered PreOut
• Remote Bass Knob or Remote Amplifier Control Center (RACC) ready
• STAR Topology
• 8.5 Volt Input Capability
• Extra-Large Gold-Plated Power and Speaker Insert Terminals
• Top-Mounted Controls
• Control Panel Cover
• Blue Power Indicator
• Integrated Wire and Mounting Screw Covers
• Variable Turn-on Delay
• Output Disable[/b]
JulianThis optional Control Centre makes it possible to control and link one or more (up to eight) mono block amplifiers and control them from one unit. It lets you name each amplifier and make specific adjustments. You also have complete control over all amp functions, and the large bright display shows you the amp data including temperature, amperage and voltage monitoring. This is the ideal way to setup an eight amplifier, eight subwoofer system for sound competitions or just to enjoy earth shaking bass sound.[/b]
