Amp Problem
993 Views 5 Replies 4 Participants Last post by  Kenitz
Hi, I'm having a problem with my amp, so anyone who can help just gimme some advice...
The amp has power, it's on, there's a flow of electricity to it, my connections are solid, but there's no thumping. I tested the speaker wires and there's no power to them at all from the amp.
What I was going to try is replacing the RCA cable,but until I get some free time I thought I'd check to see what you guys think it could be.
Thanks
It's broken? RCA cables are rarely defective to the point that no sound comes out. Also check the source (your head unit.) Make sure that the RCA outputs are turned on.
I had this problem too, ended up needing a new amp. Did you check the fuses on the amp? Maybe the amp just died on ya...?
Yeah I checked the fuse, it's fine, there's power and such like I said..just no sound. The only thing I can think of is the amp is messed..
you say youre connections are fine make sure every wire goes where is should and then check again and then once more if you mess up anywhere or something just isnt touching right you wont have sound, make sure everythings in its place, if not they yes try another sub and see if you get the same results.
This is old, I fixed it, it was the RCA cable..
