Here's the scoop. I installed 2 bass shakers, hooked them up to my amp, to the same channel my subs are on (2 polk 10's). Switched on the stereo and everything worked for about a half second, then i lost all the speakers/subs that are hooked to the amp. None of the fuses are blown anywere. I unhooked the bass shakers and now the amp turns on, and stays on, as long as the volume is at or below 4. anything higher and it cuts out. there is also a faint beep when the whole audio system turns on. Any ideas?
oh, and it's a 600W 4 channel Jensen (i know...there's the problem, it's a jensen)
