99 DOHC Taurus, the alternator does not charge the battery, but the little warning light does not come on either. I need to crawl under and check the wires, but was wondering if anyone has any thoughts? My manual says to check the wires, battery connections and fuses. I tried to check the 175 amp super fuse tonight with an meter, but I think I need to disconnect one side to check it. Both sides registered 12 volts, but one side is from the battery and the other is from the alternator, and they may both have voltage all the time. Anyone know anything about the super fuse?
