So I read through most of the related threads, but I failed to find someone with my exact code....
44=RH Primary Crash Sensor Not Mounted to Vehicle Properly
Any guides/pics greatly appreciated.
Thanks!
A flashing airbag light can mean one of two things. The first possibility is that your battery is in death throes. Have it tested at your local auto parts store. The second possibility is that there is an actual problem with the airbag system. Below is a list of airbag codes, which will flash on the warning light. For example, the light will flash once, pause and then flash twice == 12.
12=Low Battery Voltage
13=Air Bag Circuit Shorted to Ground
14=Primary Crash Sensor Circuit Shorted to Ground
21=Safing Sensor Not Mounted to Vehicle Properly
22=Safing Sensor Output Shorted to Battery Voltage
23=Safing Sensor Circuit Input Feed/Return Circuit Open
24=Safing Sensor Output Feed/Return Circuit Open
32=Driver Side Air Bag Circuit High Resistance or Open
33=Passenger Side Air Bag Circuit High Resistance or Open
34=Driver Side Air Bag Circuit Low Resistance or Shorted
35=Passenger Side Air Bag Circuit Low Resistance or Shorted
41=RH Primary Crash Sensor Feed/Return Circuit Open
42=LH Primary Crash Sensor Feed/Return Circuit Open
45=LH Primary Crash Sensor Not Mounted to Vehicle Properly
51=Air Bag Diagnostic Monitor Internal Thermal Fuse Fuse Blown Due to Intermittent Short to Ground
52=Backup Power Supply Voltage Boost Fault
53=Primary Crash Sensor Circuits Resistance to Ground or Air Bag Diagnostic Fault
When the airbag light is flashing, the computer sees a problem in the system and the airbag will not deploy.
This code means the passenger side impact sensor is falling/fallen off of it's mounting point on the radiator support, behind the front grill. It needs to be mounted and grounded well to clear the code/light. Had same problem on a G2 years ago. Sorry, no pics...
