1 - 12 of 12 Posts
ok so i today i finally get around to hooking up my air to fuel ratio and i was excited...everything was goin great and i mean great....then as the 9 hour day and 2 air to fuel gauges later( 1st ones backlight didnt work) im hookin it back up to my 12v starter cable so that is has power and for some reason when i plug it back in it doesnt start......im pissed now....long day....tired... cant figure it out...and some of the wired looked charred so i ran new wiring and the damn thing still wont start....so after all day of workin on the car .....im ready to hit a punching bag :angry: any input from u guys would be nice....i have a g4 taurus......am i able to buy the new harness that goes the the 12v starter .????if so that might fix the prollem cuz see i go to work in this car....i dont think ive ever been this mad at my car.....everytime i go to do something electrical...it messes up and i cant drive my baby..........i just felt like writing this down cuz i hate seein my car broke ...shes my pride and joy and hopefully well get her fixed
- :( big z-
kina sounds like his brain is fried. why are you hooking the wires to your starter? are you using the instructions for this air/fuel gauge? for power, there are usually a couple of constant "hot" terminals in the fuse block that are unused, that you can tap into for something like a gauge. why are you needing an a/f gauge anyway, is it boooooosted? <_<
12v ignition for a power source
and after i did new wires from both ends it still didnt work....and it doesnt say ne thing about a fuse the ignition in the manual
Check every single fuse in the power distribution box under the hood. I am guessing that you cooked one of the ignition fuses (on my SHO there are many of them)
Never!!!! use the iginition as a source of power. there are constant power sources in the fuse box. They are usually marked "batt" or "pos". I'll be suprised if you didn't zap your ECU...ECM...computer...whatever you want to call it. Personally, I would have someone install this one, you obviously don't have the right equipment to tell which wire (s) your tapping...tap into the wrong one for the o2, and you WILL fry the computer
I use it as a signal wire :ninja:
A faulty switch vulcanized the wire insulation and blew a 40 amp ignition fuse <_<
Uhhhhhhhhh....
.....something tells me I don't think you should be messin' with ANY wiring on your car then <_<
Discussion Starter #10
i know alot of people that use the ignition as there 12v power source and and i knew what i was doing but i just accidently charred a wire when i was using my shrink tubing so im about to go out now and check it out
wish me luck
Discussion Starter #11
:chili: yyyyyyaaaaaaaaayyyyyyyyyyy its finally fixed.....couple blown fuses....new wiring .....and a new power source for my gauge...and now it all works fine!
yay :chili:
1 - 12 of 12 Posts
About this Discussion
4 Participants
96SHO
Full Forum Listing
