Okay... the new shop called back and advised that the ONLY thing that they could fine wrong was that the pressure-sensor 0-ring on the drier/accumulator was torn... it must've have slipped out and gotten caught on the threads when I turned it onto the drier/accumulator during replacement. Fixed, leak tested, recharged, out the door, $63.00. A far cry from $1,500.00. He also advised that some of the condensor fins were beat up, but that I still had most of the fins in good shape.
The thing is... it's hard for me to castigate the place that gave me the high estimate. I also have an F-150 that was having oil-pressure problems, and a different shop advised it was the oil pump... an $800 repair. I took it to the high-AC-estimate place, and they found that it was merely oil that hadn't been changed for a long time (that's another story about a different bad shop altogether) -- gummed up inside the motor. An engine flush and oil/filter change later, I was out-the-door for about $100, and I've not had a problem since.
The moral of this story is that on any given day, any given shop could try to scam you, intentionally or not. If possible, when you are facing an expensive repair estimate, get a second opinion from a shop that has a good reputation. This forum is also an excellent place to check with.
Thanks, all...
Sean Douglas
Norman, OK
[email protected]
Thanks, all...
Sean Douglas
Norman, OK
[email protected]
