Well I went to check out the noise I get when I drive at high speeds. I already posted about this, I quote my own post here:
More...? sure: At high speeds on highway, there is a low humming noise. I think it comes from the wheels or something. When I got the car, the back wheel's break (I don't know what part of it, I think it's the plate that the breaks press on, I am missing the jargon) was really pressing on the wheel and it rubbed it hard when I drove, I have to get it fixed. Maybe it's connected to this problem? The humming noise starts at around 50mph, and reaches a peak at 60 - 65. it is monotonic, like a wavy sound, the frequency changes with the speed. when I go over 65 and into 70, the noise is gone. anyone has any idea what's that about?
The garage guy said something about a certain part, but I'm not sure what he meant, something I think with J that sounds like jet, jack, maybe... I'm sorry I really don't know 90% of all the mechanical talk... Anyways, the guys says it will cost me about $300-400 to take care of it. I wonder if that sounds reasonable to you?
I would like to know too. I just had both front wheel bearings replaced for a bit over $200 EACH. And I thought that was high. What parts are involved and how hard is the labor?
Chung,
He said he have to take the wheels off and look inside to see serial numbers or something... he said it's a lot of work and would take him a while. Can this problem get worse?
G
I see from your profile that you have a Gen 3. $200, or even $300 a side is a fair price. There's alot of labor involved. The knuckle has to come off, then the bearing needs to be pressed out, and a new one installed.
I don't know if there's any right now, but a while back there were front knuckles, brand new, on Ebay for $99 for two. (There's one knuckle on either side of the front.) This way, you get new bearings, ball joints, and a new knuckle for a super low price. I would recommend you check into those, and ask your mechanic if he'll put them on if you bring them to him. You'll probably end up spending the same $300 or so, and have all new parts.
*edit*
Found some! Here's a link. Knuckles (no, not the brass ones!)
The Gen 3s need the entire knuckle replaced in front. This includes a new ball joint. I bet $150 from Ford each. You can find them on eBay for $100 a pair.
In the rear you need to get a new hub and new retaining nut, ~$60 IIRC. Easy job in the rear. PITA for the front.
I see. I was beginning to think twice about the shop I've been going to for the past 3 years. I guess they are still honest. Good to know. Thanks.
