When you guys installed your aftermarket radios in your gen 4's, specifically ones with digital climate control, did you have to run radio wires and the antenna wire from the amp in the rear to the new head unit? Also has anybody used the metra digital install kit in there gen 4? If so how did it fit, how did the install go, and what all did it come with?
Spend my 02¢ wisely...
You do have to run a harness to the rear. As the RCU is in the trunk that's where all the speaker wires are at, in addition to the antenna wire. All the wiring comes with the dash kit. It's very easy to run them down the driver side of the car. All the panels just snap off. Even if it's your first time you can install the kit in under an hour.
This^ The hardest part is removing the faceplate. Other than that its a piece of cake!
Try these babies out. They're stereo removal tools. You can score them anywhere, including Wal-Mart, for a couple of bucks. I can remove my radio in 10 seconds.
