1 - 2 of 2 Posts
2001 Ford Taurus SES where can I run a power wire into my Taurus for a amp ? Any pictures or advice?
I have 2004 and ran the main power under the brake booster. It was really tight but worked out good. There is also a spot above the fan blower motor. No matter where you run your wire make sure you use a good properly sized grommet and double check that you won't damage anything when you drill your hole.
1 - 2 of 2 Posts
