i have question i cleaned the throttle body on my 97 mercury sable dohc,,i started taking off down the road came to a stop sign then when pushing on the gas pedal it was stuck like it was binding up ,, i made sure it was working before i drove the car,,kept pushing the gas pedal finally i could push the pedal and drove the car i wonder if i messed up the tps sencor or mabe i messed up the throttle body or something else,,,,now the car has a ruff engine idle ...also driving the car a certain spot in the throttle theres a miss in the motor ,, then the motor smooths out the car has plenty of power with no hesitation ,, sometimes you can drive the car it idles smooth other times i get a ruff engine at idle and 1 time the transmission had a harsh shift,, it could be vacumm leak i replaced the MAF sencor with a autozone duralast part which i heard there not that good i tryed finding a motorcraft part ...mine was tested bad,, put a new motorcraft IAC from the ford dealer ,i did pull the neg cable off, and drove the car to relearn the computer,,, the idle seem a little lower at idle,, the car has a ruff engine idle,, the car has 131,000 miles ,,i tuned up the car at 90,000 miles
