21 - 37 of 37 Posts
Also, dorman products sell aftermarket Paint to match.
Part number 79358 - 1996 - 2002 style.
Part number 79359 - 2004 - 2007 style.
No keypad installed. Just another Avenue for availability.
Sent from AutoGuide.com Free App
That would be your best option but I would go one step further and bring the dental tool I mentioned and look for one of these DRL-High SJB's for some DRL fun.
Don't forget the C2280f plug and as much wiring as possible from the donor car. Getting the plugs depinned is not complicated and if you have to Jerryrig it by bypassing the door can and going under the door panel with a nice wrapping of electrical tape to prevent shorts that can work also. These four wires and a ground or 2 from inside your door will get you punching numbers in no time.
The C2280f plug
http://i1169.photobucket.com/albums/r501/blkfordtaurusman/1372548382_zpsf8e48ef9.png
The SJB 2004-2007 general diagram
http://i1169.photobucket.com/albums/r501/blkfordtaurusman/1372552658_zpsd1bcb801.png
The C510 Door can diagram
http://i1169.photobucket.com/albums/r501/blkfordtaurusman/1372548407_zpsa73017d8.png
Hold on.
If you have remote entry (clickers), your SJB already has capability. Not sure where blackfordtaurusman is getting his information - not correct.
There are 4 SJBs.
w/DRL w/remote entry
w/DRL w/o remote entry
w/o DRL w/o remote entry
w/o DRL w/remote entry
If you have remote entry, you have the "high series" box, meaning capable of auto lamps, remote entry, keypad entry, alarm etc. YOu just have to run the wires and add the functionality.
Discussion Starter #28
well that makes things A LOT easier then. Can I grab any Gen 4 keypad then and it'll be compatible? There were three or four keypad entries at that JY but not in my color. I'll gladly pay the $20 to get a door handle and then paint it if all I need is just a G4 keypad
As for DRLs can my SJB be reprogrammed to not have the DRLs on or do I need an entirely different SJB?
You should grab a keypad from a 2001 and up. That's when they changed the button schematic. 2000MY uses the Gen 3 buttons schematic.
The handle can be from 1996 - 2002 if styles not matching is OK.
Otherwise any 2004 - 2007 will match your style
Early 2003's match 2002
Late 2003 matches 2004
What savo said on the keypad. 2001 and newer.
Find a handle on a 12/2002-1/2003 or later built car to match the style of handle on your 2004.
You need a different SJB. DRL can't be programmed. You need a different one.
I have a spare 2004-07 SJB with high series features and no DRLs. Do you still need one?
For the low low price of free? :<
I will sell it for a reasonable price, with USPS flat rate service to your door. PM me with an offer.
21 - 37 of 37 Posts
