1 - 2 of 2 Posts
Discussion Starter · #2 ·
As a follow-up. The 2015 Taurus uses a micro min fuse type. You CAN'T use that same type for the add a circuit. It bottoms out in the fuse box that holds the fuses. I know this seems 'off,' but you need to use a MINI ATM fuse add a circuit like this:
Those fit perfectly and I used fuse slot 34, which comes on when the car is started and off when it's turned off. Perfect!
1 - 2 of 2 Posts
