PLEASE HELP! I have a 2003 ford taurus ses. About a year ago it started running 3-4000 rpms when i put it in park. When I'm accelerating around 35-45 mph, theres a loud rattling under the hood and when I let off the gas the car briefly surges. Now it accelerates by itself and still wants to go when I'm at a stop. I've had spark plugs and wires replaced, gasket heads, pcv valve, MAF sensor, iac valve, egr valve, throttle position sensor all replaced. Throttle body and intake totally cleaned. Mechanic did a smoke test and found no vacuum leaks. Also had throttle cable checked, perfectly intact. No one can figure this out. Please help. Also sometimes if I adjust the pedals while going down the road the rpms increase.
Motorcraft IAC or POS aftermarket part? The ONLY IACs that work on these cars is the Motorcraft unit.
Was the PCV valve a Motorcraft unit? Again aftermarket PCV valves are junk and can cause your issues.
What engine do you have? Vulcan or Duratec? IACs are different between the 2 engines, but will physically fit either engine so be 100% sure the correct Motorcraft IAC was installed.
What are the long term fuel trims on each bank? (Check with a scan tool that shows live data) High positive trims at idle that drop under load are indicative of a vacuum leak.
MAF issues are virtually unheard of on either engine. MAF can be checked by looking at measured air flow under various conditions with a scan tool to determine its health.
The engine is a duratec. The IAC was not motor craft. I'm not sure about the PCV. That would make sense because the issue started right after PCV was replaced
Must have MC PCV. Been there, done that, aftermarket is high flow and high rpm. In addition you will need the new hose/elbow as in the pic. Original often leaks.
Best of luck.
