So I have a 2012 Taurus and all of a sudden the entertainment system turned off and the AC got stuck blowing hot air for no reason.
217980
I reset the car through the battery with no success, so I took it and did a check on the PCM and got a bunch of faults that neither me or the guy doing the check understood.
217981
217983
217984
217985
Now I'm stuck not knowing what to do, fix, or change. Can Someone help?
2013 Taurus Limited
I'm no mechanic but I'd look for a loose connector behind the center stack's control panel.
May be a stupid question but have you checked fuses associated with the radio, air conditioning controls. I'm sure you have already just trying to cover all the bases.
Other then that it sounds like a bad controller/module. Sometimes that stuff just goes out without a warning.
Your DCCV has shorted out and burned out the Climate Control Center along with part of the entertainment center. This will be an expensive repair.
Tom in Dallas
