2003 Ford Taurus
I have checked the fuses, relays and connections still no AC clutch engagement.
I looked at the clutch gap but not sure what tap is supposed to be, (.02-.035)?
Problem started when friend took his car to Firestone for power steering issue. They got ps fluid all b over the compressor and cleaned it off. I checked clutch connector, cleaned and reinstalled but still no engagement. I want to check voltage to clutch but it connector is located in a hard to access place with little or no room in connector for my DMM probe. Also the instrument cluster lights went out at the same time. Any suggestions?
You can do the "broomstick test". Start engine and turn on AC on during a hot day when AC would normally run or jump the CCPS so the clutch would normally engage. Take a stout stick (broomstick, etc) and use it as a lever against the inner fender, etc and the clutch plate to push on the clutch plate. If clutch engages with a "push" either the clutch gap is too large (common) or the clutch coil is partly shorted internally and not producing a strong enough magnetic field (much less common).
I know this sounds like BS, but it works.
Clutch gaps on most cars is typically .025" to .028". I dont remember the exact spec on the Taurus.
2003 Ford Taurus
I actually tried it but it wouldn’t engage. But I Appreciate the help
What happens if you jump the clutch coil to the battery? Does the clutch pull in?
2003 Ford Taurus
I haven’t tried it yet as the connector is hard to get to. I now have a schematic to access off the relay. I will be working on it Sunday when I am off work. I appreciate your input, thank you.
If you know which relay is the clutch: it has 4 sockets for the pins on the relay. Numbered as in the pic. Need to know which is which, one goes directly to the clutch. Make a wire with a 1/4' spade on one end, other end to the battery positive. That hot wires the clutch. In my pic I hot wired the starter to bump the engine over. Pic of typical wire diag. for A/C clutch.
