Hi all. I have a 99 Taurus SE with the front disc rear drum brakes. I've got a abs light that comes and goes and the shops I've talked to want $90.00 to scan it. Is there a key trick like on some other cars so you can retrieve trouble codes from the pcm? The reservoir is full the pads and shoes are new and the system has been bled. Thanks.
Does the light blink at all when it comes on? Mine came on once...it blinked a two number code....I think it was 42 or something like that. It blinked 4 times...paused then blinked 2 times. If yours is doing that...Count the blinks and get the code.
