i replaced the master cylinder and a ajuster rod on one of the rear tires we did everything to it and the abs light and break light keeps on
You are going to have to have a dedicated ABS scanner to figure out what the problem is. Generic code readers won't pickup ABS problems.
Mike
B)
The ABS on my 2000 taurus was malfunctioning. It was active whenever I stopped and sounded terrible. I took it to Firestone and they put in new pads and turned the rotors. After a test drive the mechanic said the ABS needs looking at. I thought new pads would take care of the problem. I actually thought the rotors were shot to the point of metel to metal. After looking at the ABS diagrams I deceided to disable it by pulling a 10amp fuse in the box next to the battery. I tried about 4 fuses before I found the right one. Now the ABS light stays on and also the emergency brake light stays on but it brakes very,very nice.
hey i have the same problem but i cannot fined the fuse for it
