· Registered
I'm guessing this means that the ABS module is dying, its doing the thing where sometimes when I am coming to a slow stop (on dry pavement) I feel the ABS engage.
My question is how much is this going to cost me to fix, or should I just live with it?
G
You never know, it could be a faulty sensor on a wheel causing it to go nuts because it thinks the wheel is going at a different speed. I know there are special abs codes, you may want to look into having those read.
· Registered
I've had the same problem in my '94 SHO. Sometimes while braking slowly the abs kicks in, and when it does, I apply very little pressure to the brake pedal and the car come to an abrupt stop. The pedal feels like there is alot of pressure until I let off the brakes, then the car resumes as normal. Sometimes the abs light comes on and goes off. Other times it stays on until I shut the car off. I haven't been able to figure this one out.
