Which would be louder:
- a single 12" sub rated at 800w rms and 1600w max
- dual 12" subs , each rated at 400w rms and 800w max
***both are in sealed boxes of same material
Assuming that the box size is calculated correctly for each, the material is similar etc....
___________________________________________________________________
I am trying to pair some subs with a Rockford Fosgate amp rated at 2400w max and 800w rms @ 4 ohms.
I am looking at either
- 2 Audiobahn 1251T's (400rms/800max) each
- 2 Rockford Fosgate HE2's (400rms/800max) each
- 2 Volfenhag ZX4712's (500rms/1000max) each
- 2 Volfenhag ZX4812's (600rms/1000max) each
- 1 Audiobahn 15" AW1500Q High Excursion (800rms/1600max)
I know the Audiobahn and Rockford's match the amps RMS and stay inside the max power, and both the Volfenhag's go over the RMS rating on the amp but stay at or below the max output. What do I do?
Also, how would I want to wire them? x2 2ohm in series OR x2 4ohm in parallel OR some other way?
AND... How can you tell if subs are a fake- like a set off ebay maybe? :ripped:
Thanks
:coin: ha ha
Thanks
:coin: ha ha
