Ok, I never really used the A/C in the bull because I wanted to save on gas mileage, but since my uncle is driving it now, he wants it on. I tried to turn on the A/C a couple of days ago, it didn't get cooler, even when set to MAX. I bought one of those refill/recharge kits with the gauge, used the gauge and it says the freon is ok (its in the 25-45 psi range); is that the normal range for the A/C system in a Gen2 Taurus?
I didn't hear the anything clicking on (usually means the A/C clutch is kicking in) when I first turned on the A/C, until the engine fan came on - then I heard a distinct clicking/cycling on of something every 15 seconds or so.
Any thoughts? Ideas? Oh yeah, about 2-3 years ago we had the accumulator/drier and the hi/lo pressure lines replaced and the whole system was converted to r134a. The A/C worked fine then.
Ok,
look to see if the compressor is kicking on. Second, since it was converted, anything goes. With R-134a, you really need high and low side readings. The low could be 25-45 while the high could be over 350 (Way to High)
Get both readings and make sure that it is working first, then get back to us.
