Cooling season is on again off again and soon to be on for an extended period. The A/C on my '05 sable has decided to take the summer off. I dumped in two cans of R-134 about two weeks ago and it worked for a few days and has now gone back to non functional. I can by pass the pressure switch and make the compressor work, but as soon as you take the by pass out it quits. Must have a leak somewhere, but nothing obvious. Anyone got a "usual" trouble spot to look for? The car has 132k on it. :(
Look for oil or dye on the hoses and at the connections.
If you cannot locate the leak, refill the system with dye and get a UV light.
Do not use stop leak!
QUOTE (eminem3150 @ May 29 2009, 12:05 PM) index.php?act=findpost&pid=728853
Do not use stop leak![/b]
No oil or wet spots on hoses or connections that I can see. Haven't gotten really up close and personal with it just yet. Thought this would be a good place to start. The dye and UV light sounds like a good idea. Where does one get this dye? O'Reilly, AutoZone, etc....? What sort of procedure is required to troublshoot using this method? And thanks for the reply, much appreciated. :)
Usually, this dye is put in at the factory.
You should not have added any refrigerant without first knowing how much was in the system in the first place.
The A/C will not work properly if it's overfull either. You need to read the pressures with a manifold gauge set to know if it's undercharged, overcharged, or if there is a different issue.
QUOTE (Mr. X @ May 29 2009, 02:08 PM) index.php?act=findpost&pid=728884
The A/C will not work properly if it's overfull either. You need to read the pressures with a manifold gauge set to know if it's undercharged, overcharged, or if there is a different issue.[/b]
Hmmm.. Didn't know that about the dye. Good to know and a good idea.
I assumed (yes I know what "assuming" will do) that since the A/C clutch would not engage normally and would when by-passing the pressure switch that the refrigerant was low. I've got a little handy dandy fill hose with a gauge on it for the low pressure side and it indicated low refrigerant also. So that is why I added refrigerant and it did work well for a few days and now it is dysfunctional once again with the same symptoms.
I'll have to see if I can locate a UV light and see what I can come up with. Will have to see if I can locate my gauges also. Have moved and not everything is readily available. Thanks for the info. :)
They sell the UV dye kits at most parts stores. That's where I'd start.
