My A/C and heater only work on full blast. They don't work at any lower setting, no air comes out, but just fine on full blast. Anyone else have that problem? I'm wondering if it's something I can fix myself, as long as I'm practicing my DIY skills.
I swear I'll stop asking questions soon, I'm almost done with my repair work, there's just so much I want to know. But thanks for all the help :wub:
Your blower motor resistor has gone bad. Usually somewhere under the dash, not sure where it is on a Taurus though.
Well, it seems I cannot edit my previous post... According to Haynes the blower motor resistor is located on the evaporator case under the right side of the dash. Looks like you will need to remove the glove box to get in there.
I would unplug the wiring harness from the resistor and check for resistance across the terminals, no idea what the pinout is though.
Good luck!
