What mild mods can I do to my v8 sho. A side of cold air and exsaust, I'm told that befor I use nos I have to wed my cams I don't wanna get into the motor. Programmers, diffrent spark pugs or coils.
its more like a 100 percent chance that the cams will fail if not fixed....it is absolutely imperative that you get them welded...V8sho.com has alot of good info on who you can go to to get that done and they have alot of other ideas for performance upgrades and maintaince..and if they do blow there will be NO money coming from ford because there was a class action lawsuit filed against ford for the cam fail and ford wonno gaurentee they will fail but i hear its a 60 some odd percent chance, not worth it imo, i dunno the car is better stock and unbothered, id keep it that way hadnt i already messed it up. article i read is projecting the car to double in bluebook in about 7 years so. might not hurt either to pull off a valve cover and jot down the serial number on the cams in there, i did that only to find out mine were aftermarket "fix" cams so ill blame it all on ford if it blows and get some cash from them. otherwise im at 122,000 fresh off a rebuild over winter of the entire engine and trans all seals and gaskets remachined. and my cams look brand new. but pay no mind to my luck i have a dead lifter or 2 haha. anyway, get em welded that cars a dime and they are dissapearing quickly[/b]
