1 - 2 of 2 Posts
is it possible to remove toe motor while leaving the trans in the car. it appears it will clear with not much room to spare, but looks as if it should. found a crack in middle piston on front bank which explains the misfire. so i'm just changing the engine. heads and intake is all of the engine. so all i see holding it is the two mounts on passenger side, and trans bolts. water pump is off. unplugged crank sensor and removed ac compressor. anything else?
the guy that did my 97 did it from the top.
Its tight but possible
1 - 2 of 2 Posts
