99 SE 3.0 Duratec, AC bearing and clutch assembly replaced a couple of weeks ago. (Had seized up broke the belt). Got it home, drove fine about a week, now the belt doesn't move. Replaced the tensioner, no help. All other pullys move just fine.
What else do I need to check?
You need to replace your main pulley or the harmonic dampener as they call it at the parts counter. It will be a ***** as it is threaded onto the crank on the duratec engine. If your belt isn't turning, that is the ONLY possibility. The rubber on the dampener has sheared apart like my friend's duratec did.
