ok guys i need help quick with this... i am supposed to go on a 250+ mile trip on sunday and something obviously screwed up today... it all started at once... got in started my car and i was driving down the road and i accelerated to 30 and i noticed it was speeding up to about 35... tach was about 1500-1700 in gear with my foot completely off the gas pedal... and when i got to a stop sign it was running very rough and idle at about 400-500... almost dying... later on at home i had it in park and it actually did die from running so low of rpms... popped the hood at home and noticed a hissing noise almost like a vaccuum leak near the throttle body area... not sure what the issue is but can anyone help me?? i need to get this fixed asap! by the way its the duratec.
If you are hearing a rushing air sound...peak around under there, look for frayed or deteriorated vacuum lines. I had one on a valve cover that had separated from the nipple, my MPGs were done ~5-6MPG (obviously different symptoms from you).
i just went and looked again... i do not visibly see any bad hoses or anything and i used a very bright craftsman 19.2v flourescent work light.... i did happen to notice the hiss is stronger around the intake... if there is anything wrong i am guessing its behind the intake on the backside of the motor near the firewall... if it was an intake gasket would it cause it to do what its doing now?
Spray connections and hoses with carb cleaner until the idle surges/dies. Your vac leak is where the carb cleaner causes the change in idle.
