I tagged on to a posting yesterday, and got some initial troubleshooting info. I applied this to my A/C troubleshooting, and here is a list of my symptoms and some observations.
1. No Cooling Air, at all.
2. Under the hood, a relay clicks about every 5 seconds.
3. At each click, the inner pulley on the A/C compressor with 3 each 1" diameter bosses on it engages and spins for a few seconds.
4. After stopping, it spins again on the next click. (repeats.)
5. When spinning, it appears to be operating normally. No noise, no wobble.
This seems to indicate a low coolant (R-134, according to the sticker). The info I got yesterday was that of removing a shim. Does the fact that the clutch spins the inner pulley eliminate that possibility?
Thanks.
Larry
I am trying to diagnose mine as well and what it seems like is if you can catch it while it is not working, bump it with a broom stick and it should engage. This would indicate the shim fix. If it is litterally turning on and of as rapid as 5 seconds, then I am not so sure. In my case it will work sometimes as well, but it can stay off for quite a while. I am waiting to catch it while it is not working and then try the broomstick and see if that will engage the clutch.
Sounds like the typical low on refrigerant symptoms I've seen plenty of times.
If you jumper the low pressure switch on or near the reciever / dryer as a test it should stay on.
I had convinced myself that it was a low-refrigerant problem, and needed to wait to the weekend to address it.
At my Beloved Local Wal-Mart, I purchased an 18 Oz. can of Interdynamics' EZ Chill, the product with the gage on it. FYI, the Interdynamics web site has an extensive "how-to" video library.
I carefully followed the instructions in what turned out to be an easy, straightforward "topping-off" procedure It accepted the full can, and this amount of r-134A maintained a pressure of 33-38 psi at the completion of the fill process. This is the "blue" or "filled" range (25-45 psi) noted on the gage, provided.
The A/C is now blowing chilled air, and appears to be working normally. The reseach project took 4-5 days, the process itself, about 10 minutes. The only problem is that the original charge went somewhere, and, of couse, there's a possibility that this could only be a temporary fix. We'll see.
Based on my vast experience of 10 minutes in the Automotive Air Conditioning repair field, I would like to stess that it is crucial that you use a gage during this process. Without the gage to verify when the system was corrctly charged, I would have stumbled around in the dark, and probably have added a second can "just to be safe". As a minimum, I would have wasted $10-$12, and perhaps have damaged or compromised the A/C system on the auto.
On my '99 Sable Duratek, the low pressure A/C fill port had a black cap and was located on the passenger's side, at the firewall. It is 10" behind, and directly in-line-with the lid on the Power Steering reservoir.
(Confusing note: There is a similar, but much larger diameter, fitting jutting vertically up in front of the Coolant recovery tank. It is physically much larger than the low-pressure port. I assume this to be the high-pressure port, and of course wanted nothing to do with it. The re-fill connector wouldn't fit on it anyway. Basic safety design, I'm sure.)
